Hi Guys,
Please can you tell me what is the box for the V1000
Garth
Hi Guys,
Garth
Hello Garth, it depends…
Generally you get the following:
Most part numbers include the Radio, Wall/Pole bracket, hose clamp and gland. In addition you get a 15W 1G POE brick and a mains cord which you can select depending on the part number.
Here’s the data sheet: 60 GHz cnWave V1000 Datasheet - English
If you want a PTP link, preconfigured to work out of the box, we do have the Bridge in the box 1G, which is two V1000’s already programmed as a controller and client, just power them up and point them at each other and you’ll have a layer 2 bridge.
