Hello Everyone,
Can anyone help me here can Cambium XV2-2T1 Wi-Fi 6 Outdoor Access Points
can device back side is anble to give up to 1 killomete like front side because is 360 degree.?
The XV2-2T1 has an integrated sector antenna.
The XV2-2T0 has an integrated omni (360) antenna.
this device back side coverage also up to 1 killomete like front side
i am so greafull to hear from you
1 km WiFi distance is going to depend on the user device(s) as well because that is pretty far for WiFi. If anything can do it it’s this beast. Below you can see the antenna pattern for the 2T0. By looking at that it would appear that there should be no noticeable change in performance from front to back.
The XV2-2T0 is at the zero point. I walked the path marked on the distance markings while on a wifi call. The phone finally dropped off the XV2-2T0 when I entered the barn. Because there is an XV2-21x right by that door.
Below is the XV2-2T1 antenna pattern from the datasheet. As you can see, it is not designed to have the full coverage from the back of the AP as it has 120 degree directional antennas.
Ok let me go direct to the point
Where I want to install this access point XV2-2T0 is when I stand in the middle of the place distance up to the end is 1 kilometers
XV2-2T1 Coverage is 120 degrees and needs 3 devices to cover 360 degrees becoming very expensive for me
So I was asking for the coverage of XV2-2T0 if 1 device is enough for that and the back side of the devices is also the same coverage like front side
If not what about e501s can you break it down for me because this devices is also 120 degrees I can manage to buy three to cover 360 degrees
1km is pretty ambitious. It depends if this is open space or has trees/buldings/obstacles. We have deployed the XV2-T0 units and get 2-300m in a tree studded environment but after this range, we have issues with the client device as it is able to receive signal but not send as transmit power too low.
We did do a site test also with Meraki and the Cambium far outshone in field tests.
To elaborate, we installed 10 units over a roughly 2 Sq km location (but numerous trees).
Thanks what of this Cambium network e501s coverages
