Can I fit external antennas to Canopy 5.4GHz 30/60 Mb BH?
Yes. Canopy 5.4GHz 30/60 Mb BH is available in a Connectorized form factor. However it should be noted that the transmit power will need to be adjusted to conform to the EIRP limits applicable to the country of deployment. In the case where Canopy 5.4GHz 30/60 Mb BH is to be deployed in ETSI regions, the maximum transmitter power will need to be reduced to comply with the 27dBm EIRP limit. The power setting can be calculated from: Maximum Power (dBm) = 27 New Antenna Gain (dBi) + Feeder Loss (dB).
