Can not upgrade ePMP 1000 2.4 GHz Integrated Radio firmware
Hi.
I need help.
I have always tried to upgrade firmware for ePMP 1000 2.4GHz Integrated radio but it keeps on sending errors, When I use both URL and from local file.
this has happened on all the ePMP 1000 radios i have worked on.
Kindly help with a solution
Regards
2.4 ePMP1000 usually come with software version 2.0. These radios need to be upgraded to version 2.6 first, then can be upgraded to the most current software version.
