Is it possible to eliminate a particular Cambium ID? Are there any limitations about the numbers of Cambium ID that we can administrate in a particular account ?
Currently we don't allow/support deletion of Cambium ID. As such there is no limitation on number of Cambium ID(s) created under a company account.
I forgot my onboarding key, what do i do?
You can always reset your onboarding key by login into cnMaestro account.
Once you log into your cnMaestro Account, Select the Account for which you want to change the onboarding key
and then navigate to Operate->Onboard Devices->Claim from Devices you will see onboarding key , there is option to edit as well.
Hi Lee,
We cannot edit the cambiumID or Account ID .
KR.
Hi KR,
Thanks you your reply.
But had other method to fix it ?
Lee
