i have difficulties on getting the IP address. i fear one of my staff changed the default ip address… can anyone help me…
naz wrote: i have difficulties on getting the IP address. i fear one of my staff changed the default ip address.. can anyone help me...
Assuming you have physical access to the unit, you could always create a default plug, insert it, reboot the SM, and log in to it using factory default settings.
do u have the layout of the connections within the pins. :). i’m afraid i might shortcircuit the device.
RJ11/6pin - jumper pins 4 and 6. Plug into the radio and boot. The radio will be at the default IP address with no password.
Thanks for the tips…
Regards
Naz
AKAtek
naz@akatekgrp.com
is there any manual on how to upgrade the software…
at this moment the canopy is running
CANOPY4.0.1 Jun 25 2003 10:23:22 SM-DES
sorry i’m new at this… hope u guys can throw in few pointers… :oops:
thanks
Naz
AKAtek Co.
