Can't enable eth2 on e600 on 4.x firmware
got the issues on fw 4.x.x (tried all the fw in this number). Can’t enable the eth2
Hi @slayerette
Eth2 is enabled by default on the E600 AP.
You can connect a computer to the Eth2 port using an Ethernet cable to verify the connectivity.
If you need more help on this, please elaborate on the issue you are facing with the Eth2 port.
Additionally, you can create a support ticket with the tech dump file attached and share the ticket number here.
So it just Data port and cannot power up any equipment?
Hi @slayerette
That’s correct; the Eth2 port on an E600 AP is just a data port. It cannot power up any PoE devices.
