I had 4 SM’s that are changed state from REGISTERED to GRANT and dropped the connection they then stay in the GRANT state and will not reconnect. They had been in a connected state for about 33 hours, I disabled CBRS and they still would not connect i am thinking this a AP problem. However I have additional SM’s across the system that are disconnecting but showing the state as authorized.
Has any one else had issues with CBRS causing hardware failures or am i chasing the wrong tail.
David
