Centos 6 32bit CNUT
I have been messing with this for a while. I can't seem to get it going. I get No SNMP Response when I try to refresh my network elements. Here is the errors I am getting hopefully someone has some good tricks to help me out
Thanks in Advance!
06/13/17 15:40:23 WARN   	NE at:169.254.1.1 No SNMP response
06/13/17 15:40:23 INFO   	Refresh Selected Network Elements process has completed.
06/13/17 15:46:23 INFO   	Canopy Network Updater Build Version:4.10.5 Loaded.
06/13/17 15:46:23 INFO   	Current User: root
06/13/17 15:46:23 INFO   	Java Version: 1.6.0
06/13/17 15:46:23 INFO   	Platform: i386
06/13/17 15:46:23 INFO   	Operating System: Linux
06/13/17 15:46:23 INFO   	OS Version: 2.6.32-696.el6.i686
06/13/17 15:46:23 INFO   	Loading prefs from: /usr/local/cambium/networkupdater/pref/canopy_swupdater_pref.txt
06/13/17 15:46:23 INFO   	Load network from file:/root/net.net
06/13/17 15:46:25 INFO   	Refresh Entire Network process start ..
06/13/17 15:46:25 INFO   	Refreshing NE at:169.254.1.1
06/13/17 15:46:25 INFO   	Starting Http Server on host:fe80:0:0:0:a65d:36ff:fe5a:fc8f%2
06/13/17 15:46:25 INFO   	Generating certificate for host:fe80:0:0:0:a65d:36ff:fe5a:fc8f%2 ...
06/13/17 15:46:26 INFO   	Starting server on HTTP...
06/13/17 15:46:26 INFO   	Server on HTTP started
06/13/17 15:46:26 INFO   	CNUT Http Server started.
06/13/17 15:46:43 WARN   	NE at:169.254.1.1 Not responding, status/version unknown.
06/13/17 15:46:43 INFO   	Refresh Entire Network process has completed.
06/13/17 15:46:48 INFO   	Refresh Selected Network Elements process start ..
06/13/17 15:46:48 INFO   	Refreshing NE at:169.254.1.1
06/13/17 15:46:48 INFO   	SNMP Session Manager pool size = 10
06/13/17 15:46:48 WARN   	java.io.IOException: java.net.UnknownHostException: Tech: Tech
06/13/17 15:46:48 WARN   	NE at:169.254.1.1 No SNMP response
06/13/17 15:46:48 INFO   	Refresh Selected Network Elements process has completed.
06/13/17 15:47:08 INFO   	Refresh Selected Network Elements process start ..
06/13/17 15:47:08 INFO   	Refreshing NE at:169.254.1.1
06/13/17 15:47:08 WARN   	java.io.IOException: java.net.UnknownHostException: Tech: Tech
06/13/17 15:47:08 WARN   	NE at:169.254.1.1 No SNMP response
06/13/17 15:47:08 INFO   	Refresh Selected Network Elements process has completed.
06/13/17 15:51:08 INFO   	Refresh Selected Network Elements process start ..
06/13/17 15:51:08 INFO   	Refreshing NE at:169.254.1.1
06/13/17 15:51:08 WARN   	java.io.IOException: java.net.UnknownHostException: Tech: Tech
06/13/17 15:51:08 WARN   	NE at:169.254.1.1 No SNMP response
06/13/17 15:51:08 INFO   	Refresh Selected Network Elements process has completed.
Please check the read write community string entered for the device.
