Thanks @GaryHans for the tip! Is there a way to change this setting vi cnMaestro? I try to execute this command on all the APs and it works but after that I see all the APs out of sync. As soon as I execute the synchronization the force power return to default. How can I solve this?
Thank you very much!
Best Regards
Emiliano
Hi Emiliano and welcome to the Cambium community. Please add the command “power force 802.3bt7” (without parenthesis) to your AP Group(s) configuration as a User Defined Override. Please let me know how that works for you.
Hi @GaryHansen thanks for your support, the change works
Thank you very much!!
Glad to hear that fixed your issue and glad to help.
