Why from few days on cnMaestro channel 100 and higher are not supported for e410 ?
This is huge problem for some implementations !
Not In Sync Sync Configuration Configuration failed: radio2_channel_list:invalid channel list
@PFR could you please confirm whether you are using cloud or onprem? also could you please share the version details?
Cloud.
All was ok till today.
After syncking I have messages like above.
And 5Ghz stop working on e410 (old and new !!!)
Now I have
Channel All and 5Ghz is set to channel 36, but power is 0 !!!
Why ??
OK when we have setting outdoor for e410 5GHz not working !!!
Why ?
Are you using same AP Group for both e410 and XV series APs.
No. In this groups are only e410
We are not seeing same issue here in our lab and can you please update us exact steps to reproduce the issue and also software version running on cnMaestro and AP.
If possible can you please invite me to your account i will check and update you
ashok.kumar@cambiumnetworks.com
Short path how to check it:
1.Create AP group
2. Set country to Poland
3. Set oudroor for this group
4. In 5 GHz set specific channel and put the list 100 112 116 136 140 inside filed.
Save and try to synchronize.
The error will be Not In Sync: Configuration failed: radio2_channel_list:invalid
It worked without any problem till end of last week.
Now we have an issue with all e410 on 18 controllers !!!
It is really A-blocker ! for us
Think about changes made for xv3-8. You chaned channel for radio 2 (>=100) and radio 3 (up to 64). Maybe this changes affected e410 ?
And now most importnat
Channel list on e410 synchronized week ago
Interface: radio2 Country:PL
CHANNEL MAX-POWER EIRP MAX-POWEREXT
36 18 23 0
40 18 23 0
44 18 23 0
48 18 23 0
52 18 23 0
56 18 23 0
60 18 23 0
64 18 23 0
100 25 30 0
104 25 30 0
108 25 30 0
112 25 30 0
116 25 30 0
120 25 30 0
124 25 30 0
128 25 30 0
132 25 30 0
136 25 30 0
140 25 30 0
Channellist on device synchronized after cloud update (today)
36 18 23 0
40 18 23 0
44 18 23 0
48 18 23 0
IT IS REALY INTERESTING!!! Who made this fu**up ?
EMPTY list with outdoor setting
Please keep the discussion civil.
sorry but too much aps not working
Software 4.2.1 fix this problem - confirmed
!! If u have mixed enviroments 410A & 410B - ugently upgrade to 4.2.1 if it will be available from cnMaestro !!
