We have several customers that are using the Cisco Anyconnect VPN Client on their laptops and/or desktops. When connecting to the Cambium R200/201 routers they are NOT able to access the VPN, however if we bypass the router we are able to connect to the VPN. We have enabled the settgins under the ALG: ALG Settings PPTP, L2TP, IPSEC and still no luck. We have upgraded firmware to latest and greatest and still no luck. Does anyone have a work around or ran into this issue?
Hi
We did not observe any issue with Cisco Anyconnect VPN. VPN is working fine with ALG disable and enables on the both Ethernet and wireless interfaces.
Please see the attached screen capture:
- Cisco_Any_Connect.JPG (56.9 KB)
- Cisco_Any_Connect_1.JPG (62.9 KB)
- Cisco_Any_Connect_3.JPG (86.6 KB)
Hi ,
Please send the device configuration to my email id (niraj.mahapatra@cambiumnetworks.com)
Regards
Niraj
