I would like some assistance on the cisco configs to enable multicast packages to work with vlans.
We have a netwrok in place where-by we configure vlans for clients on the Cisco 1841 router
! interface FastEthernet0/1.110 description IPTV-SM encapsulation dot1Q 110 ip address 41.79.230.77 255.255.255.252 ip pim version 1 ip pim dense-mode no cdp enable !
and we enable the vlan id on the cisco 3560 switch. The AP and the IPTV Server are on the same switch..
The SM's are given the vlan id's and the /30 ip addresses are configured on the client computer/router/STB.
We have tested the AP and the SM without the vlans whereby we have connected the IPTV Server and the AP on one switch and the STB behind a SM and are able to view the TV Channels. However when we put it on our current setup with vlans we cant seem to get the TV Channels show. We can see from the SM's Monitor > Performance that it is receiving the multicast packages but the TV channels dont show.
Just few questions to clarify your setup. Does your client computer/router/STB expect tagged or untagged packets? Can you please also share your SM Vlan settings.
My client end expects tagged packets as without the /30 ip addresses the client computer/router/stb it does not connect.
In regards to the SM we simply Enable the Data Vlan and give the vlan id to it.. Configuration > Network > Data Vlan (check the Enable), and the Data VLAN ID.
I have set up a test system with one AP and one SM
AP: 41.75.150.200 username/password: admin/admin
SM: 41.75.150.201 username/password: admin/admin
On the Cisco router we have the following configured for this test vlan. wr-leaf1#sh run Building configuration...
Current configuration : 17617 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname wr-leaf1 ! boot-start-marker boot system flash c1841-adventerprisek9-mz.124-2 boot-end-marker ! logging buffered 4096 debugging no logging console no logging monitor enable secret 5 $1$feNo$dByjXyHKeZRbk9FWh0PaE/ enable password 7 070622494308175541 ! no aaa new-model ip cef ip cef accounting non-recursive ! ! ip dhcp ping packets 0 ! ! no ip domain lookup ip multicast-routing ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 ! ! ! ! ! ! ! ! ! interface Null0 no ip unreachables ! interface FastEthernet0/0 description Fiber link to KDN ip address 197.155.93.105 255.255.255.248 ip cef accounting non-recursive external ip route-cache flow duplex auto speed auto ! interface FastEthernet0/1 description Connection To Cisco 3650 Switch ip address 41.79.229.1 255.255.255.0 secondary ip address 41.75.150.1 255.255.255.0 secondary ip address 10.20.10.1 255.255.255.0 secondary ip address 10.30.10.1 255.255.255.0 secondary ip address 10.50.10.1 255.255.255.0 secondary ip address 41.79.228.1 255.255.255.0 ip accounting output-packets ip nbar protocol-discovery ip route-cache same-interface duplex auto speed auto ! interface FastEthernet0/1.110 description IPTV-SM encapsulation dot1Q 110 ip address 41.79.230.77 255.255.255.252 no cdp enable ! interface FastEthernet0/0/0 switchport access vlan 22 ! interface FastEthernet0/0/1 ! interface FastEthernet0/0/2 ! interface FastEthernet0/0/3 ! interface Vlan1 no ip address ! interface Vlan22 description Fiber Connection to KDN ip address 41.222.10.242 255.255.255.252 ! router bgp 37165 no synchronization bgp log-neighbor-changes network 41.75.144.0 mask 255.255.240.0 network 41.79.228.0 mask 255.255.252.0 neighbor 197.155.93.106 remote-as 30844 neighbor 197.155.93.106 description KDN neighbor 197.155.93.106 update-source FastEthernet0/0 neighbor 197.155.93.106 soft-reconfiguration inbound neighbor 197.155.93.106 prefix-list DEFAULT in neighbor 197.155.93.106 prefix-list webrunner_kdn out neighbor 197.155.93.107 remote-as 30844 neighbor 197.155.93.107 description KDN neighbor 197.155.93.107 update-source FastEthernet0/0 neighbor 197.155.93.107 soft-reconfiguration inbound neighbor 197.155.93.107 prefix-list DEFAULT in neighbor 197.155.93.107 prefix-list webrunner_kdn out no auto-summary ! ip forward-protocol sdns ip forward-protocol nd ip route 41.75.144.0 255.255.240.0 Null0 ip route 41.79.228.0 255.255.252.0 Null0 ! ! ip http server no ip http secure-server ! ! ip prefix-list DEFAULT seq 10 permit 0.0.0.0/0 ! ip prefix-list webrunner_kdn description blocks_advertised_kdn ip prefix-list webrunner_kdn seq 10 permit 41.79.228.0/22 ip prefix-list webrunner_kdn seq 20 permit 41.75.144.0/20 snmp-server community WebRunnerLeafRouter RO no cdp advertise-v2 no cdp run ! ! ! control-plane ! ! ! line con 0 line aux 0 line vty 0 4 password 7 login ! scheduler allocate 20000 1000 end
wr-leaf1#
Current status, without vlans the multicast packages pass well and the TV shows through the AP and the SM.
However when we enable the Vlans on the SM and put in this vlan id 110, and in turn put the /30 ip addresses on the STB the TV channels dont show.
