Where can I find info regard the CLI interface. I 2 PTP links behind a router that I can’t Web into. The only way I can get to them is via telnet.
Charlierest,
Are you able to get into the web interface when directly connected? Have you ever been able to access the web interface? Is there anything on the router blocking port 80?
The only things that can be done from the CLI is upgrading and resetting the radios.
