We are having a debate in a new system design. We have a few engineers in favor of using a CMM2 and some in favor of CMM Micro. I am just wondering what are the benifits/disadvantages of using either?
CMMmicro:
Managed switch with Web Interface
Supports VLAN per port
Provides GPS staus
Allows power cycling of the POE to each radio
Provides MIB info so it can be monitored
CMM2:
Dumb switch with POE
Jerry,
Being fairly new to Canopy,I bought Packetflux gear which apart from connecting a PC has no monitoring tools,is this likely to be a problem in the future,if I can afford it should I be buying CMM Micros or is it not going to be that much of an issue ?
Without more info about your deployment, growth expectations, budget, etc I can’t really say. Syncpipes are certainly economical…
