Hi ,
Can I power up the CMM4 with 24V DC power system if I use only PMP100 devices ?
In the manual is described that CMM4 need 30V DC power.
Lori,
I think they went to a 30V power supply to ensure enough current is available to power all of the 24V devices.
If you check the specs I think you will see a range from 24V to 36V with 30V being optimum.
Please verify this before connecting anything.
Hi Agin,
In the manual there is one picture of CMM IV with descripton for one of power portes:Two 56 VDC input
terminal blocks for future use.What does it mean ? Can I use the CMM4 with 48V DC ?
Lori,
