The CMMmicro is a great little box. Saves much space and time on tower tops. Problem is we MUST have port based VLAN support. The switch chipset made by Broadcom that Motorola uses states it supports port-based VLAN’s but apparently Motorola does not support it in there firmware yet.
Will we ever see port based VLAN’s on the CMMmicro? Does anyone else need them? Anyone know of a small VLAN switch that supports port-based VLAN’s that will fit inside the CMMmicro case?
Thanks.
Matthew
