Ryan2
(Ryan2)
#1
I cannot configure the IP routing of EX-2010-P model.
What is the correct information for Destination Network??
I filled the 192.168.1.0 that it was showing error. As Below
Furthermore, how can I save the ip route setting? I tried a few times,
But the setting did not change.
My local network setting:
IP of EX-2010-P: 192.168.1.209
Subnet mask: 255.255.255.0
Gateway: 192.168.1.254
TamN
(TamN)
#2
I am not clear about your question.
Do you want to assign an IP address 192.168.1.x to VLAN 1?
Here's an example to assign 192.168.1.101 to vlan 1:
config terminal
interface vlan 1
no ip address
ip address 192.168.1.101 255.255.255.0
To add a static route:
config terminal
ip route 192.168.1.0 255.255.255.0 <next-hop ip>
To save the configuration in flash:
copy running-config startup-config
