Mk_mohamed
(Mk_mohamed)
#1
Hi all
i facing Problem with Cn wave Proudect and
this is the closest thread to my problem.
Simple lab setup:
- v5k configured as PoP DN with on-board E2E
- v3000 configured as CN
- v5k status is online initiator
- A link is established between the v5k and v3000
Layer 2 bridging is on
My issue is that I cannot get the v3000 to show up as ‘online’, always in ‘offline’ state. .
Please take in your account i read this topic about same Problem and i didnt know How i correct the IPV6
Thank you in advance
James_Mifsud
(James Mifsud (Certified Instructor))
#2
Hello,
Are you indoors? As you said, this was a Lab Install.
Mk_mohamed
(Mk_mohamed)
#3
Hi
no its outdoor installtion
Mk_mohamed
(Mk_mohamed)
#4
James_Mifsud
#6
I was just thinking about this, your post says you’ve established a link, but it’s showing offline status;
This sounds like a IPv6 routing issue between the E2E and the remote node
Hi Mk_mohamed,
I need field diagnostic of V5000 and V3000 to share more comments.
please refer below link that would assist you
Thankyou
