Hi There,
I've started playing around with cnArcher which is pretty great but I've run into an issue which seems rather difficult to get around to . So everything works great up to the point where the CPE / SM connects to the AP which passes the connecting SM it's designated IP address via Radius which is different then the default 169.254.1.1 address. This basically leave cnArcher stuck at this point : Connecting to AP.
Any idea how to get around this issue ? Perhaps you guys can add a field where one can specify a secondary address or something ? Or perhaps get cnArcher to connect to the SM via it's mac address ? Almost the same as how winbox works for Mikrotik routers?
Thanks in advance.
-steph
