cnArcher v2.0.71 beta for iOS and Android is now available. This is an update to the cnArcher 60 GHz app. For details about the transition from cnArcher to cnArcher 2.0, please see cnArcher transition to cross-platform app.
Joining the beta program
To join the Android beta, go to cnArcher 60 GHz app page in the Play Sore using your phone, scroll to the bottom of the page and under “Join the beta”, tap “Join”.
To join the iOS beta, install TestFlight on your iOS or iPadOS device. Then open the cnArcher 60 GHz in TestFlight and click the “Accept” button to accept the beta terms of service and join the beta. You will now be able to install the beta version.
If you have “cnArcher 60 GHz” app installed, please uninstall it before installing the beta version.
What is new
This is an update to “cnArcher 60 GHz”. The app is renamed to “cnArcher 2.0” and adds support for PMP450 family of SMs. A future update to the beta version will add ePMP support.
The following features are supported for PMP450.
- SM Installation
- SM Quick Align
- SM Software upgrade
- Installation summary
- Demo mode
- Onboard to cnMaestro cloud
The following features available in cnArcher is not yet available.
- Onboard to cnMaestro on-premise
- Software update and configuration template push via cnMaestro
- Installation summary upload to cnMaestro X
Please post feedback and bug reports about the beta version to this thread.
