cnHeat - Imperial system Only - add metric
Hi All,
Just thought I would let you know that only a few countries use Imperial, so it would be absolutely fantastic if you could add in metric options for Tower height etc.
Unless there is a setting somewhere I have missed.
Cheers.
Christopher,
Most of the cnHeat interface does use both metric and imperial.
You are right. Under radio configuration there are a few settings that are explicitly imperial. We do have a ticket to fix this.
