The Signal Strength feature has been released for cnHeat LOCATE. When a user clicks on a location in a heat map for a site(s), the AP Site Bubble appears and now also shows the Minimum SM Height required to realize coverage and the RSSI that will be attained for each site with coverage.
Signal Strength is captured in the AP Sites Bubble.
This information is ideal to quickly understand how to connect an install location to any site with coverage. It also provides an operator with the ability to load balance between sites when good coverage is available at an install location for more than one site.
Signal Strength indicates two possible AP sites to use for coverage providing flexibility for customer loading on the AP sites.
