CNMaestro 5.2: Network Statistics can't order by RSSI, MCS, Retransmission Rate etc
Am I missing something or has some genius at Cambium further “improved” CNMaestro? Previously I could customize the columns order by RSSI or MCS or retransmission rate to easily identify our worst stations. I’m now given a less than helpful WiFi symbol below the Radios column that I have to mouseover to get details. To sort, I now have to export all of this to a CSV.
Why would any NMS designer think this is an improvement?
Previous CNMaestro
CNMaestro 5.2
Hi @scracha,
“We apologize for the inconvenience caused. We understand your concern and appreciate your feedback. Please be assured that we are working to address this in future releases of cnMaestro.”
Thanks @DurgaPrasad . look forward to it!
@DurgaPrasad Is there perhaps an RC version of CNMaestro you could release that has some of these features sorted/reverted? Getting pretty desperate for this.
Also for some reason you can’t sort Offline radios by Status (the amount of time/days they’ve been offline) in the inventory anymore?
Hi @DurgaPrasad , Similarly we can’t order LAN interface by port speed. I tried working around this by exporting to CSV but it appears to truncate the port speed on the export, only showing “Up” or “Down”. We (and most ISPs) require this to ensure customers are getting 1Gbps on their LAN and not slowed to 100Mpbs (or worst case 10Mbps) due to faulty cabling, POE or older routers.
