Hi all, as suggested by Jordan I post again in this topic to give visibility to this feature request.
We have cnMaestro on premises. We want that this tool help wisp to automate some tasks to spend less time in installations at least first two points are useful for all wisps to avoid unnecessary operations.
here is the flow
1) Automatic onboarding (if there's already a Cambium id why have I to onboard manually?)
2) With Onboarding Key the possibility to push firmware to a device when device connect to Maestro (firmware coul be choosen based on Cambium id)
3) Applying a configuration file contained in a folder called as the MAC address of the SM (or possibly a default template for other operators such as a golden file)
4) the operator's ability to put a template through ssh access to the master. (or via API)
Implementation in itself seems to require minimal effort and is powerful to save time if you want to go to a single tool management / configuration tool
The possibility to upgrade firmware based on Cambium id is more selective than Automatically Update Device Software, where you can select a global firmware target, feature already implemented in last cnMaestro upgrade.
Wisps could have different Cambium ID and different firmware choices not only for device type, for example if you want to test a new firmware only in one base station you coul assign a different Cambium ID to that Base Station SMs.
SMs that connect to that tower will have new firmware, instead all of the others site still remain with old firmware with a different cambium id.
