cnMaestro. I can not delete an AP device from an Account
Hello, I am looking for a solution with a trouble in a cnMaestro Account, in which I am member and I can’t delete an AP device.
When I try to delete it, cnMaestro shows this message:
I will thank a help about it.
Regards!
Is this a 3GHz/CBRS device? If yes, you will need to delete the CBSD first under the CBRS management tool.
Hello Eric, It isn’t a device like you describe. Is an ePMP 2000 series device.
If that’s the case, you will need to raise a support ticket.
Ok Eric. Thanks for the information!
Regards!
One thing you could try (support will probably have you try this first) is to reconnect that AP back to your network so that it can reach cnMaestro. At that point you should be able to delete the SM’s under it, and then finally the AP.
Hello Eric, I tried in that way, but I couldnt Delete It. How I Should continue?
raise a support ticket please.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
