Hi
Experiencing login issue. Getting “Login Failure, check credentials”. I only have access and i now i didn’t chnage password. Using On Prem on Virtualbox, tried Maintenance with temp password with no success.
What are the other alternatives?
Hi
Hi @Brandon_Visser ,
Could you please confirm the cnMaestro version details? Also, can you share what error was seen while trying with the temporary password?
//Indra
Apologies for late reply
VERSION: cnMaestro On-Premises 5.1.0-r4 Package
ERROR: “login failed, please check your credentials”
Tried temp password setup, same error
Could you please log in via CLI and check if there are any space-related issues? If there are, try clearing them and attempt to log in again. If not, please raise a support ticket, and we can have a quick call to look into the issue.
//Indra
please assist with link or cli commend to check
Login to the cnMaestro CLI using the default username and password (cambium/cnmaestro) and try running df -h command.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
