cnMaestro On-Premises active clients diconecting
Hello all
We have cnMaestro On-prem-enterprise instance installed.
We connected 15 AP.
Everything was ok until we implemented WoWiFi functionalities
  • Cnmaestro managed roaming
  • UAPSD
  • Fast roaming protocol functionalities OKS, 802.11r, Over-the-DS are enabled
  • RRM 802.11k
  • 802.11v
Enhanced Roaming in AP groups is enabled
Now we got allot off disconnections of active clients regardless that those clients have good RSSI and SNR. The fault went so far that clients can not connect to SSID if there are more then 20 clients in the same room.
The AP’s are XV2-2
Version of CnMaestro is 5.0.0-r5
@GregorObrez
Could you please share tech-support.
cnMaestro managed roaming does not help with Xv2-2 device models.
Thank you.
