cnMaestro OnPrem 5.1.0 not enabling Cambium Sync on Ports when pushed to cnMatrix TX-2020R-P
Hello,
We recently upgraded cnMaestro OnPrem to 5.1.0 and notice that it is not enabling Cambium Sync when pushed to a cnMatrix.
In cnMaestro, cnMatrix configuration page, we go into edit to make sure sync is enabled. We see it is getting GPS. We then edit switch ports. Under Physical, Check Cambium Sync, then save, Sync to cnMatrix and after sync, cnMaestro shows in sync. Check Switch Port and it shows enabled, though on the cnMatrix it is not.
Has anyone else experienced this?
Pertinent info:
cnMaestro OnPrem 5.1.0.
cnMatrix TX-2020R-P. Software Ver 5.0.2-r4.
Thank You
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
