Currently with cnMaestro Cloud, there is only the ability to sort/filter and select AP’s with a specific firmware for upgrading. After network bulk updates, we have found many rogue SM’s that did not take the update and are on older firmware. The only way to find the SM’s is by manually selecting the AP, and then the additional dropdown for SM’s and selecting the SM with older firmware.
It would be great to be able to sort/select all SM’s on a specific firmware and queue for upgrading, similar to the way we can with AP’s.
It is possible to sort this way in the “inventory” view, but not with the “Software Update” view.
(Support Ticket (301626))
Thanks!
