I noticed that i have an option on the Manage Subscription page to Upgrade to X-NFR
When I select the option it shows Partner ID and DOmains…
Does anyone know how this works?
The NFR (“Not for Resale”) program allows Cambium resale partners to purchase demo equipment at a discount. NFR support in cnMaestro allows those partners to use cnMaestro X with their NFR equipment.
If you are a Cambium resale partner, you can read about the NFR support on the channel partner portal (look for PMB-1601). If you aren’t a channel partner, I’m afraid this option does not apply to you.
Thanks for the reply… Read the PMB-1601 and its clear…
