CnMastero - Change native Vlan for APs
Hi, I’ve a Cisco CBS350 switch, with native VLAN 10, and VLANs 100, 120 tagged on the port. I need to change my Cambium APs native VLAN to 10 from 1. Using cnMastero, Is the below step is all that is required under AP Group profile Network settings?
Yes, that would be right place to change your Native VLAN for your Cambium APs
