Network operators need it to be easy to achieve outstanding performance on enterprise networks.
cnMatrix switches with cnMaestro management and cnPilot enterprise WiFi access points deliver high performance with:
Policy-Based Automation: The ability to profile devices and automatically configure the switch providing a zero-touch experience even when deploying, disconnecting or moving network devices.
Find out more in the cnMatrix brochure.
Cambium Networks’ next generation switching platform offers a cloud managed, high performance, feature rich enterprise grade ethernet switching solution. The cnMatrix™ platform of switches provides:
- Easy and simple free cloud management with cnMaestro
- Zero touch deployment of switches makes deployment easy
- Zero touch policy based configuration enables automation, reduces errors and network downtime
- Device profiling, automatic port configuration and network segmentation improves security posture of the network
- Wireless Aware: Together with Cambium Networks cnPilot Wi-Fi solution, enables a simple, easy-to-use cloud managed Unified Wired-Wireless access solution
- Affordable, high quality and enterprise grade Layer 2, Layer 3 feature set The cnMatrix series of fully managed switches delivers full Layer2 and Layer 3 capabilities with enhanced access security. cnMatrix switches deliver power savings with several models offering fanless operation.
The cnMatrix switch series offers flexibility with 4 – 10 Gbps (SFP+) uplinks on the 28 port models while offering 2 - 1Gbps (SFP) uplink ports on the 10 port models.
Check out the cnMatrix Spec Sheet.
cnMatrix switches simplify network deployment and operation. When deployed with cnPilot WLAN access points and the cnMaestro management system, network operators have an affordable, feature rich, high quality unified wired/ wireless enterprise grade network. Improve performance, security and end user satisfaction while reducing costs.
Watch the cnMatrix intro video.
cnMatrix switches include cloud management with the free cnMaestro controller.
cnMaestro’s free cloud-based management platform provides rich lifecycle management, configuration and control, and security services; which can also be made available with on-premise deployment options
Find out more about the cnMaestro management system
cnMatrix switches include Policy Based Automation. This gives network operators the ability to profile devices and automatically configure the switch providing a zero-touch experience even when deploying, disconnecting or moving network devices.
Get the details on cnMatrix switches in our Spec Sheet.
cnMatrix switches include enhanced security features at no extra charge. The Auto Policy Wipe feature improves security by automatically removing all associated dynamic configuration when a device disconnects.
What happens to your network if the cloud goes down? With site survivability, cnMatrix switches provide uninterrupted operation even when cloud connectivity is lost. Get the benefits of the Intelligent Edge solutions from Cambium Networks.
When there is a problem, it makes sense to segment and isolate the root cause. Auto Device Segmentation provides a secure environment for critical network resources by automatically placing devices in the appropriate network segment based on their profile.
How do you manage and troubleshoot your Wi-Fi network and switches? The Wireless Aware feature in cnMatrix switches enable policy automation, easy monitoring, and troubleshooting of the unified wired/wireless network. Make it easy.
How much are you really paying for Wi-Fi cloud management? cnMaestro’s free cloud-based management platform provides rich lifecycle management, configuration and control, and security services; which can also be made available with on-premise deployment options.
