I have one quick question: As far as I see, the RFC 4133 Entity_MIB (Version 3) is not implemented in cnMatrix Switches. Is there any plan to do this in the future?
Is there a specific table within the Entity MIB that you need? Can you give us a little more detail about your requirements?
thank you!
We use MacMon NAC as network security solution (macmon.eu). When I try to set VLANs via MacMon on the cambium switch (via Q-Bridge), I get the following error:
SnmpException: Error while reading [1.3.6.1.2.1.17.1.4.1.2] from 172.16.4.228: SNMP_ERROR_REPORT, code -3
We want to set VLANs (tagged and untagged) on specific ports (access, trunk, hybrid) and change the type of port. I hope that helps?
