Our first cnMatrix installation is away from the people using the network - so this isn’t an immediate problem for me.
I have noticed that the idle fan noise on the EX2028-P is louder than I would promote for use in an office. In this case, I’m used to the MikroTik 24 port PoE switch and the previous generation UniFi 24 port PoE switches. Both are very quiet once they have finished booting (they both slow the fans down significantly - and only speed up if power demand requires it).
Is there any chance the fan speed on the EX2028-P would be reduced further in future firmware updates?
It’s a disappointing no response has come from this question. We have some EX2016M-P and the fans are very loud / tone is annoying for office use and in an open rack on the theatre stage.
Any chance of approving use of upgraded fan, Noctua NF-A4x20 PWM Cambium?
(They work when the pins are rearranged😏)
No I would say they are steady, certainly from a noise perspective. You wouldn’t believe the night and day sound difference the Noctua fans make. Hopefully Cambium can certify for permanent install
James_Mifsud
(James Mifsud (Certified Instructor))
#7
