cnMatrix Switch EX1010-P Passive PoE
Hi, I just want to make sure, does EX1010-P support Passive PoE for ePMP series? It doesn’t say anything that it does, so I suspect it doesn’t? I would probably have to go with TX series?
As long as the ePMP device supports 56v PoE, the Ex1010-P can support AP’s (for example ePMP 3000 AP, or micropop, but not ePMP3000L, or any of the Force xxxx SM devices. The 3000L and the Force xxx SM’s require 30v PoE, which the switch cannot provide. The PoE power budget is max 30 watts per port, to a maximum of 75 watts total for the EX1010-P switch.
