cnPilot E400 errors after upgarde to 3.10.2-r1
Hello!
Yesterday I updated my cambium WiFi e400 AP to 3.10.2-r1 firmware.
My system have master and 3 slave AP.
After  the update, the following errors appeared in the log:
SYSTEM-CONFIG-APPLY-FAIL: Error applying configuration [wlan1_conn_logging_port:specified parameter less than minimum]
SYSTEM-CONFIG-APPLY-FAIL: Error applying configuration [wlan4_dns_logging_port:specified parameter less than minimum]
and ETC
As result - configs at the AP are not synchronized.
Config file:
"country_code": "OT",
"syslog1": "",
"syslog2": "",
"syslog1_port": 514,
"syslog2_port": 514,
"tz_name": "Europe/Moscow",
"ntp1": "pool.ntp.org",
"ntp2": "time.google.com",
"admin_password": "*******",
"management_http": true,
"management_https": true,
"management_telnet": false,
"management_ssh": true,
"led": true,
"lldp": true,
"poe_out": "off",
"snmp_trap_ip": "",
"snmp_local_ip": "0.0.0.0",
"snmp_read_community": "private",
"snmp_write_community": "public",
"name_server1": "",
"name_server2": "",
"domain_name": "",
"ip_route": "",
"ldap_server_host": "",
"ldap_server_port": 389,
"tunnel_encapsulation": "off",
"tunnel_l2tp_remote_host": "0.0.0.0",
"tunnel_l2tp_dns_remote_ip": "0.0.0.0",
"tunnel_l2tp_local_ip": "0.0.0.0",
"tunnel_l2tp_auth": "admin:admin",
"tunnel_l2tp_auth_type": "",
"tunnel_l2tp_user": "admin",
"tunnel_l2tp_pass": "admin",
"tunnel_l2tp_created": false,
"tunnel_l2tp_mss_clamp": true,
"tunnel_l2tp_pmtudisc": false,
"tunnel_l2tp_tcp_mss": 1410,
"tunnel_l2gre_created": false,
"tunnel_l2gre_remote_host": "",
"tunnel_l2gre_dns_remote_ip": "0.0.0.0",
"tunnel_l2gre_local_ip": "0.0.0.0",
"tunnel_l2gre_dscp": 0,
"tunnel_l2gre_mss_clamp": true,
"tunnel_l2gre_pmtudisc": false,
"tunnel_l2gre_tcp_mss": 1410,
"dos_protection_ip_spoof": false,
"dos_protection_ip_spoof_log": false,
"dos_protection_icmp_frag": false,
"dos_protection_smurf_attack": false,
"pppoe_server_enable": false,
"pppoe_server_created": false,
"pppoe_server_shutdown": true,
"pppoe_server_mss_clamp": false,
"pppoe_server_management_access": false,
"pppoe_server_vlan": 1,
"pppoe_server_mtu": 1492,
"pppoe_server_auth": "admin:admin",
"pppoe_server_user": "admin",
"pppoe_server_pass": "admin",
"zapd_start_stop": false,
"config_as_cli": "",
"ip_interfaces": [
"vlan": 1,
"ip_address": "",
"subnet_mask": "",
"ip_mode": "dhcp",
"nat": false,
"enable_dhcp_server": false,
"in_members": false,
"start_address": "",
"end_address": "",
"network_ip": "",
"network_mask": "",
"primary_dns_server": "",
"secondary_dns_server": "",
"default_router": "",
"domain_name": "",
"lease_time": ""
"aps": [
"mac": "00-04-56-B2-38-1C",
"wlan_group": "Default",
"name": "315-1",
"location": "Floor 1",
"enable_24": true,
"enable_5": true,
"channel_24": "3",
"channel_5": "40",
"power_24": "25",
"power_5": "25",
"ip_address": "",
"subnet_mask": "",
"ip_mode": "dhcp",
"domain_name": "",
"nat": false,
"dhcp_default_router": ""
"mac": "00-04-56-B2-6D-12",
"name": "315-0",
"location": "Floor-0",
"enable_24": true,
"enable_5": true,
"channel_24": "3",
"channel_5": "40",
"power_24": "25",
"power_5": "25",
"ip_address": "",
"subnet_mask": "",
"ip_mode": "dhcp",
"domain_name": "",
"nat": false,
"mac": "00-04-56-B2-6C-D8",
"wlan_group": "WG2",
"name": "315-3",
"location": "",
"enable_24": true,
"enable_5": true,
"channel_24": "Global",
"channel_5": "Global",
"power_24": "Global",
"power_5": "Global",
"ip_address": "",
"subnet_mask": "",
"ip_mode": "dhcp",
"domain_name": "",
"nat": false,
"mac": "00-04-56-B2-37-F0",
"name": "315-2",
"location": "Floor-2",
"enable_24": true,
"enable_5": true,
"channel_24": "12",
"channel_5": "112",
"power_24": "25",
"power_5": "25",
"ip_address": "",
"subnet_mask": "",
"ip_mode": "dhcp",
"domain_name": "",
"nat": false,
"wlan_groups": [
"name": "Default"
"name": "WG2"
"wlan": [
"group_name": "Default",
"name": "1-1",
"vlan": 3,
"vlan_pool": "disable",
"enable": true,
"hidden_ssid": false,
"uapsd": false,
"qbss": false,
"roaming_preauth": false,
"roaming_okc": false,
"roaming_11r": false,
"roaming_11r_over_ds": false,
"allow_tkip": false,
"client_isolation": false,
"client_isolation_dynamic": false,
"proxy_arp": true,
"unicast_dhcp": true,
"drop_multicast_traffic": false,
"gratuitous_arp": true,
"dynamic_auth": false,
"dynamic_vlan": false,
"mesh_auto_detect_backhaul": false,
"dhcp_option82": false,
"tunnel_mode": false,
"session_time": 28800,
"inactivity_time": 1800,
"security": "wpa2-psk",
"passphrase": "DP31511",
"band": "both",
"band_steer": "normal",
"nas_id": "",
"pmf_state": "disable",
"pmf_sa_query": 100,
"roaming_11r_reassoc_timeout": 20,
"pmf_assoc_comeback": 1,
"max_num_clients": 64,
"dtim_interval": 1,
"guest_access": false,
"ga_wispr_ext_post": false,
"ga_mac_fallback": false,
"ga_sa_prefix_query_strings": true,
"ga_session_time": 28800,
"ga_inactivity_time": 1800,
"ga_proxy_redirect_port": 0,
"ga_portal_mode": "internal-access-point",
"ga_access_type": "click-through",
"ga_connection_mode": "http",
"ga_sp_title": "",
"ga_sp_text": "",
"ga_sp_terms_msg": "",
"ga_sp_url": "",
"ga_sp_logo_url": "",
"ga_sp_bg_url": "",
"ga_external_portal_type": "standard",
"ga_success_action": "logout-page",
"ga_sa_logout_page_text": "",
"ga_sa_redirect_url": "",
"ga_cn_portal_name": "",
"ga_ldap_basedn": "",
"ga_ldap_userdn": "",
"ga_user": "",
"ga_user_passwd": "",
"dhcpopt82_circuit_id": "",
"dhcpopt82_remote_id": "",
"rate_wlan_downlink": 0,
"rate_wlan_uplink": 0,
"rate_client_downlink": 0,
"rate_client_uplink": 0,
"sa0": "",
"sa1": "",
"sa2": "",
"sa3": "",
"sa4": "",
"sa5": "",
"sa6": "",
"rad_auth_1_host": "",
"rad_auth_1_secret": "",
"rad_auth_1_realm": "",
"rad_auth_1_port": 1812,
"rad_auth_2_host": "",
"rad_auth_2_secret": "",
"rad_auth_2_realm": "",
"rad_auth_2_port": 1812,
"rad_auth_3_host": "",
"rad_auth_3_secret": "",
"rad_auth_3_realm": "",
"rad_auth_3_port": 1812,
"rad_acct_1_host": "",
"rad_acct_1_secret": "",
"rad_acct_1_port": 1813,
"rad_acct_2_host": "",
"rad_acct_2_secret": "",
"rad_acct_2_port": 1813,
"rad_acct_3_host": "",
"rad_acct_3_secret": "",
"rad_acct_3_port": 1813,
"rad_mode": "load-balance",
"rad_proxy": false,
"rad_acct_sync_records": false,
"rad_auth_timeout": 3,
"rad_auth_attempts": 1,
"rad_acct_timeout": 3,
"rad_acct_attempts": 1,
"rad_acct_interim_interval": 1800,
"rad_acct_mode": "none",
"mac_auth_delimiter": "",
"mac_auth_uppercase": false,
"mac_auth_rad_pass": true,
"monitor_host": "",
"dns_logging": "",
"dns_logging_port": "",
"conn_logging": "",
"conn_logging_port": "",
"acl_rule": [],
"ga_wl": []
Hi
Please send me an email @ pvsr.gupta@cambiumnetworks.com with the configuration file, I will test in my lab and let you know my observations. Also let me know from which version you have upgraded to 3.10.2-r1
Best Regards,
Gupta Bobby
We are also having the same issue any fix released?
We have identified the root-cause and a fix is under test now, we plan to release it by the weekend of early next week (version 3.10.3). Will post here as soon as the firmware is out.
Same problem with last version, i dont have l2tp in my configration.
@Bounzz
Thank you for the remote session. We managed to clone the existing AP Group and using the new one helped to push the configuration successfully.
Thank you again for the session.
