Thank you - yes - I have tried this with both AP - set them up individually with their own SSID and mesh off.
They work fine in this mode. Both can be accessed and devices retain their connection. Router is fine.
The moment I setup the mesh with Base and Client with same SSID, problem arise with the router.
Even if I connect outside the mesh on another Wifi access point, the router goes down every few minutes.
When this happens I am forced to unplub the Base unit to access the network again.
I dont believe its the DNS 8.8.8.8 but more the Base is conflicting with the router 192.168.1.1
Here are my pings to 192.168.1.1 when I enable Base/Client:
64 bytes from 192.168.1.1: icmp_seq=28 ttl=64 time=3125.783 ms 64 bytes from 192.168.1.1: icmp_seq=30 ttl=64 time=1117.062 ms 64 bytes from 192.168.1.1: icmp_seq=29 ttl=64 time=2120.884 ms 64 bytes from 192.168.1.1: icmp_seq=31 ttl=64 time=430.726 ms 64 bytes from 192.168.1.1: icmp_seq=34 ttl=64 time=51.043 ms ping: sendto: No route to host Request timeout for icmp_seq 36 64 bytes from 192.168.1.1: icmp_seq=37 ttl=64 time=1.574 ms 64 bytes from 192.168.1.1: icmp_seq=38 ttl=64 time=42.033 ms ping: sendto: No route to host Request timeout for icmp_seq 39 Request timeout for icmp_seq 40 64 bytes from 192.168.1.1: icmp_seq=41 ttl=64 time=52.653 ms 64 bytes from 192.168.1.1: icmp_seq=42 ttl=64 time=36.087 ms 64 bytes from 192.168.1.1: icmp_seq=43 ttl=64 time=38.572 ms Request timeout for icmp_seq 44 Request timeout for icmp_seq 45 64 bytes from 192.168.1.1: icmp_seq=46 ttl=64 time=36.373 ms 64 bytes from 192.168.1.1: icmp_seq=47 ttl=64 time=48.887 ms 64 bytes from 192.168.1.1: icmp_seq=48 ttl=64 time=62.673 ms Request timeout for icmp_seq 49 64 bytes from 192.168.1.1: icmp_seq=50 ttl=64 time=106.653 ms Request timeout for icmp_seq 51 Request timeout for icmp_seq 52 Request timeout for icmp_seq 53 Request timeout for icmp_seq 54 Request timeout for icmp_seq 55 Request timeout for icmp_seq 56 Request timeout for icmp_seq 57 Request timeout for icmp_seq 58 Request timeout for icmp_seq 59 Request timeout for icmp_seq 60 Request timeout for icmp_seq 61 Request timeout for icmp_seq 62 Request timeout for icmp_seq 63 Request timeout for icmp_seq 64 Request timeout for icmp_seq 65 Request timeout for icmp_seq 66 Request timeout for icmp_seq 67 Request timeout for icmp_seq 68 Request timeout for icmp_seq 69 Request timeout for icmp_seq 70 Request timeout for icmp_seq 71 Request timeout for icmp_seq 72
In case of mesh setup, your mesh client AP’s ethernet port should be disabled/disconnected and it should connect via wireless to mesh base AP. If mesh client ethernet is up, it will form a loop, please make sure to disable/disconnect the same.
Currently running into same problem. Have an E500 set as Base and 2 E500 set as clients. The mesh is set and runs, but refuses to hand out IP addresses to end users that connect to SSID. Tried disabling the Mesh Vlan Tagging and still couldn’t receive IP address.
Would setting the APs to a static IP address be helpful?
Why do you suggest turning off mesh? Just as a temporary fix for end users to connect to network?
