Anyone had been situation same me!My customer's use some e410 to coverage wifi for office.It is working normally now!However suddenly it is not work.I can not login by ip default 192.168.0.1 to check it.I don't know what's happen occur with it
I tried replace one new Lan cable,new injector but it is not still work and no lights
Anyone had been situation same me!Please help me! what is root cause?
Please try to login with 169.254.x.x ip address that last two octate will be decimal conversion of your device eth0 mac address. Example if your eth0 mac address is 00:04:56:91:50:10 then last two hex mac address need to be converted to decimal so in this example it will be 80.16(decimal conversion of 50 and 10). So the device would be accessible by 169.254.80.16 ip.
After login Please issue service show last-reboot-reason to know the last reboot reason and service show cores to know if there is any crash or core
While accessing the device with backdoor IP 169.254.X.X please extract techsupport dump (GUI >> Operations >> Download Tech Support) and share it via email to pvsr.gupta@cambiumnetworks.com
