I am trying to reeconfigure one of the cnPilot E430W outside of CNMaestro for testing.
I perfomred a facotry reset (?) on the cnPilot E430W by holding the reset button in for 15 seconds. I observed the device light on the fron tpower off and go to orange. Then it went off and I can no longer access the device and it does noat appear to be powering on.
I have the device plugged into a POE switch, but the poe switch (EdgeSwitch with POE+ turned on the port the cnPilot E430W is plugged into) is showing no power being drawn by the device and the light on the cnPilot E430W is not on.
Any suggestions on how to move forward? Did I brick the device?
I have connected the network Cable fromthe POE swtich to the Passthrough port on the bottom of the E430W. I have aconnect the short 'jumper' cable to the Ehter1POEIn port to the Pass Thru port (as shown in your image).
The device still does not power on (no light on the front panel).
What is the proper method of performing a factory reset on this device? Since holding the reset button for 15 seconds casued this issue. I have 8 more devices like this one and I do not want to brick another one.
