Regarding the manual, max throughput for e600 is 1300mbps so i dont see to much reasons for lag support. I think that cambium has plenty other features to add, things to fix than add lag feature (as you mentioned, now is 2019…
Is there a possibility to get our hands on the beta version? I can't seem to find it at the support center where I can download the other (non-beta) firmwares.
Why would you need it? I challenge anyone to show me a maxed out 1Gbps switch port in any real world situation. Even at MCS9 with 4 streams you are looking at 1300Mbps half duplex + 150Mbps on 2.4GHz(no you will not use 40 or 80MHz channels on 2.4GHz in any real world situation) and you have 1450 Mbps). Even with low overhead you are looking at 10% reduction in rate so you are now at 1300Mbps. Have 90% average rate in the down stream you are looking at 1170 on the interface. So basically unless you only have 2 uses sitting under the AP pulling max traffic downstream using UDP there is no way you are going to max out a 1Gbps switch port. Also best practice design with 5GHz still only uses 20 and 40MHz channels. Basically its not worth the expense of pulling the extra cable.
While LAG may indeed provide no/slight increases in maximum throughput, we consider failover/resiliency (uplinking the AP's to stacked switches) a more substantial advantage.
One thing to note is power to the AP needs to be managed in this case. ie. while LAG can help work around a failed packet path, the AP has PoE-in only on one of its (Eth1) ethernet ports. So even if you have the AP cabled up to two separate PoE switches and enable LAG, if the one supplying power goes down, then the AP will power off, even if the other switch is still up.
Ask me when the users are above 50-150 then you could be using this if my switch ports restricts me to 100 mbs , link aggregation could help in that scenario. But when they’re multiple clients download thier sweet YouTube Video or something they won’t see a ,5-6g giving out , isp which I have max is 60-90 mbs worth of data , even the app control url routes , application speed flow controls implement I might be able to smooth out but the load is the load. 7-8 pm it’s star struck . But through put does count here. I mean there can’t be 16 wlans giving a 100% 450mbs to 1300mbs throughput to all the clients . It’ll be choked at 3 clients of 5, g with 400 mbs . And 2.4 at some 6 clients. So how are they even for dense environment even…
I’ll bang may head . Still cambium being my wifi fabric lust . With little knowledge how to go along it. Mikrotik was great until it’s upgrade. Now I need mikrotik k cambium ruijee reyee combined … but all have limitations and functions. You’ll be capped chickadee
They won’t understand the pain if we lose connection via wires . The AP would still work in conjunction with the other ap . Using it’s uplink and maintain the lan side of the other location .
