The latest Cambium cnPilot Home Wi-Fi release 4.7.3 has been released. Firmware and all the documents are uploaded on the support site for supported platforms on the following links:
https://support.cambiumnetworks.com/files/r-series/
https://support.cambiumnetworks.com/files/cnpilot_r195p/
This is a maintenance release which contains several important bug fixes listed below -
Tracking ID | Product | Description |
RBN-409 | All | Default route installation failed if PPPoE is enabled over IPv6. |
RBN-654 | All | LAN port was flapping. |
RBN-697 | All | HTTPS redirection during login did not work with IPv6 address. |
RBN-720 | All | GUI was not accessible if HTTP/HTTP(s) mode is selected. |
RBN-863 | All | Device supports other than default netmask /24. |
RBN-889 | All | Deny call to any number that is less than four digits. |
RBN-1033 | All | DNS fail over related issues. |
RBN-1081 | All | PPPoE re-connection failed if the device configured in dual stack mode. |
RBN-1114 | All | Configuration issues related to EZUI. |
RBN-1135 | All | Radio failed to initialize if scheduled access is disabled. |
RBN-1142 | r201P | Call termination failed even if voice call recording is complete. |
RBN-1149 | All | Could not disable radio via cnMaestro config push. |
RBN-1150 | All | Multi WLAN profile configuration support in EZUI. |
RBN-1153 | All | End-to-End connectivity issue when station obtains IPv6 address. |
RBN-1154 | All | SIP audio codec parameter to GUI did not match. |
RBN-1159 | r195W | Resolved the WI-Fi connectivity issues. |
RBN-1171 | All | Provisioning to be triggered only after system learns DNS servers. |
RBN-1185 | r201P | Multicast was not working over NAT. |
RBN-1190 | All | Need port forward supported using TR069. An error code 9002 found while creating a new port forward rule. |
RBN-1192 | All | Issues were there in Eazy UI configuration update. |
RBN-1193 | All | Wrong information for LAN host was displayed when the raspberry client connected to LAN port. |
RBN-1195 | r195W | TCP MSS clamping support for PPPoE connection. |
RBN-1196 | r201/r195P | Constant Reboots/Disconnects. |
RBN-1225 | r195W | False event was occurred for the LAN port up/down. |
RBN-1233 | All | IP_Whitelist with Port-Forward rule. |
RBN-1235 | r201/r201P | PPPoE disconnected frequently. |
RBN-1251 | All | Aggregation and fragmentation security patch. |
RBN-1262 | All | SIP packets NAT translation failed if it was connected to LAN ports. |
