The latest Cambium cnPilot Home Wi-Fi release 4.7.4 has been released. Firmware and all the documents are uploaded on the support site for supported platforms on the following links:
https://support.cambiumnetworks.com/files/r-series/
https://support.cambiumnetworks.com/files/cnpilot_r195p/
This is a maintenance release which contains several important bug fixes and new features.
New features added are -
- Wireless events in cnMaestro
- Voice settings configuration
- Parental control
Fixed issues are -
| Tracking ID | Product | Description |
| RBN-1158 | r195W | Throughput was dropping from 25 Mbps to 1.5 Mbps if number of associated clients were increased. |
| RBN-1159 | r195W | Frequent client disconnection. |
| RBN-1194 | r190W | r190W was displayed as offline. |
| RBN-1198 | r200, r200P, r190W,r190V, r195W, r195P | Improvement in HELP text for password string. |
| RBN-1207 | r195P | Running 5 GHz Wi-Fi analyzer on the cnMaestro On-Premises, caused the routers to crash. |
| RBN-1219 | All | Dual stack home router device did not onboard to the cloud. |
| RBN-1242 | r195W, r200P | Fix for PMAC discovery. |
| RBN-1259 | r200, r200P, r190W, r190V, r195W, r195P | Fix for Feature codes *72 and *73. |
| RBN-1263 | r200, r200P, r190W, r190V, r195W, r195P | Voice settings support to configure Busy Call Forward and No Answer Call Forward. |
| RBN-1264 | r200P | Fix to select standard channels. |
| RBN-1331 | r200, r200P, r190W, r190V, r195W, r195P | LAN and wireless clients did not get IPv6 address. |
| RBN-1337 | r195W | cnMaestro was initiating the reboot. |
| RBN-1340 | r200, r200P, r190W, r190V, r195W, r195P | cnPilot Home Router UI was displaying as registered even the router was not registered with SIP server. |
| RBN-1343 | r195W | Not able to ping WAN IP from LAN clients. |
| RBN-1344 | r195P | Devices displayed the addresses even if IPv6 field was disabled |
