What exactly can cnMaestro configure/manage on the cnPilot routers?
Can we easily configure things like port forwarding, etc on these devices from cnMaestro? If not, is that in the pipeline?
i have configured everythink by script configuration!
No response from Cambium?
Currently, using cnMaestro, you should be able to configure anything that would appear in a device's exported configuration file. These files can be used as a basis for creating full or partial templates in cnMaestro which can then be pushed to multiple devices.
The file can be viewed from within cnMaestro in Configure -> Devices -> View (document icon). They can also be downloaded from the device web UI in Administration -> Management -> Config File Upload & Download -> Download.
It may be easiest to set up the configuration you want on a single device, export its configuration, cut out the portion you are interested in and create a template in cnMaestro using that.
For your example I think the parameter would be
PortForwardRules=192.168.11.2,1,2,TCP&UDP,test1;192.168.11.15,1,2,TCP&UDP,test2
