Is there a size limit on the drive to work with the R series?
Hi ,
Can you confirm what size are you trying ?
Also , which file system are you using FAT or NTFS/EXT .
Regards,
Nilesh
I do not know what our customer is trying, but is there a size limit? If I had to guess it is a 128 Gig, but can’t be sure
Hi ,
we have tried with 1 TB FAT32 and it works.
We don’t support NTFS and exFAT.
Regards,
Nilesh
