cnPilot Wireless Router Installation Instructions
User Documentation
User Guide for cnPilot Wireless Router is available for download from:
http://support.cambiumnetworks.com
Enquiries and support
Package Contents
cnPilot Wireless router package box contains following items:
Item |
Description |
Quantity |
1 |
cnPilot Wireless Router |
1 |
2 |
cnPilot Wireless Router’s Power Supply / PoE |
1 |
3 |
Ethernet cable |
1 |
4 |
ATA cables to connect Analog phone |
2 |
cnPilot Wireless Router Installation and connecting to internet
- Power ON the wireless router using the power supply/PoE. POWER LED will glow after 5 seconds of powering ON and wait for 2 minutes to boot up device properly.
- Insert the Ethernet cable to any LAN port on the RJ45 port labeled LAN1 to LAN4 and connect other end of the cable to Ethernet port of PC
- LAN LED will turn ON after connecting the LAN cable
- Configure the LAN interface of your PC to acquire the IP address using DHCP. The LAN interface of the PC will get an IP address from the 192.168.11.x/24 subnet
- Connect to the wireless router by typing https://192.168.11.1 in web browser
- Enter default username “admin” and password “admin”
- Change the default password by going to Administration->Management->Password Reset option.
- Go to Network tab and select INTERNET mode as DHCP/STATIC or PPPoE based on the internet service provided by the ISP. Most common mode of connection would be DHCP (Please refer your ISP’s instruction).
- Go to wireless tab and change the SSID name from default value to your choice of SSID. For selecting the security password for SSID go to Wireless ->Wireless Security and select the SSID from SSID drop down list and select the security type and password. It is recommended to change the wireless security password.
- Connect the WAN port of the wireless router to the ISP device (eg. ADSL, Cable Modem). Notice that WAN LED will start glowing now.
- Please save the configuration and reboot the device.
- cnPilot has PoE out functionality on WAN port which can power up PMP450 or ePMP 1000 SMs (Subscriber Modules).
- Again open https://192.168.11.1 and go to STATUS tab and see the “Network Status” for details of internet connectivity and statistics.
- Now the connection is established for configured SSID and browsing internet.
