CNPILOT R201P POE Failure to radio
I am wondering if any of you are seeing the same issue we are seeing with R201P Routers. During storms we seem to be getting a POE failure from the router to the radio. A quick router reset fixes this issue but its not ideal. Is anyone else running in to this?
A few customers reported this issue where due to thunder and lightning some surge current flowing in causes circuit to shut down. We have added extra surge protection to the upcoming Hardware (R201).
ashutosh
Thanks for acknowledging the issue but what is your fix for the hardware I have? Fixing future hardware doesn't help me at this time. What do you recommend?
My Techs have reported this same issue as well. Any updates? Solutions?
