Can someone please check the tags that describe each of the router models?
The R200 says: Cloud manged 802.11ac Single Band router with ATA for voice.
The R20P says:
Cloud manged 802.11n Single Band router with ATA voice and PoE out.
Both the 'bubbles' say 802.11ac, so I assume they're both AC, but you can't really be sure from the webpage. All of the 'bubbles' say AC, but the descriptions don't always match.
I will have to check why does the bubble and the explanation does not match, however; we have got the spec sheet which is available on the same page under resources section for all the 5 different types of these devices which will give you the correct information. Here is the info:
