Will support for ePMP 3000 and Force 300 line be added to CNUT?
It is supported... ALL ePMP radios are supported... however, it looks as though Cambium has not provided the newest 4.4.3.pkg3 file for CNUT. The newest e3k CNUT build is 4.4.1.pkg3.
I would imagine with 4.5 right around the corner, that they will most likely release a CNUT build of this as it's a major release.
CNUT is rarely used nowadays. Let me put 4.4.3 build online as well.
Dmitry
We plan on moving to cnMaestro for initial firmware and config files but haven't set up a subnet for it yet. file size on the pkg3 file was smaller than the img for 3k alone and didn't mention support for them, only gps and nongps. Thanks for clearing this up!
4.4.3 CNUT package containing AC has been posted under ePMP Supporting Tools and Files on our support site.
https://support.cambiumnetworks.com/files/epmp_tools_and_docs/
Dmitry
