CnVission solution
Hi
Will the Hub FLEXR will fit with the ePMP 2000 sector antenna??
And will be compatible to work with CnVission Mini.
Please advise asap
Yes, you can use 90/120 deg sector antenna for Hub Flexr as well.
Also it compatible with all cnVision clients including Mini
